Multifunction DAQ
How much power can I get out of my SCB-68 connector block?
I was able to connect LabVIEW to an oscilloscope and measure a signal, thanks for the help Filipe and AVR. Now I want to hook my SCB-68 connector block to a peltier cooler and control it using LabVIEW. I need at least 20 volts and .01 amps. I'm using a PCI 6052E I/O board. Any idea how much power I can get out of this setup??
(2,292 Views)
6052E board outputs follow TTL standards, that is they give 5V and more or less 10 mA. You cannot drive your device with these figures: you must use an intermediate relay capable of switching the power required.
Roberto
(2,292 Views)
