Multifunction DAQ
How much buffering does the USB 6008/6009 have?
How many readings can be stored internally before the device overflows.  Any pointers to info which describes this would be appreciated.
Thanks.
(2,965 Views)
Accepted by topic author fish8100
512 bytes.  256 samples.  This is specified in the USB-6008 user manual.  Check the specifications section, Analog Input, AI FIFO (page 24).
You can also always determine this programmatically.  Create a task of the type you want and query the Onboard Buffer Size from a DAQmx Buffer property node.
(2,962 Views)
Ok.  I missed that on P24.  Thanks.
(2,957 Views)
