09-20-2012 01:06 PM
Mark,
I have found two options for you. The first is to use the steps found in the Calibration Procedure Manual for B/E/M/S/X Series Devices (http://www.ni.com/pdf/manuals/370937k.pdf). If you look under the Adjustment Procedures, it walks through how to do external calibration. As a note, the steps it recommends to take use LabVIEW VI's for the calibration procedure so you will need to do them on your PC with LabVIEW installed (with the DAQmx driver).
The other option is to fill out a Return Merchandise Authorization (RMA) for the parts that throw this error. This means the part will be sent in and put through tests (including calibration) to get the part working correctly again. All recorded instances of this error being thrown have been because there was something wrong with the device itself. If you would like to have your devices RMA'd, you would need to call in and talk to a Customer Service Representative and Applications Engineer.
From the information I have found, there is no way to run an external calibration from Calibration Executive itself. Try these steps to work through this issue.
09-20-2012 01:44 PM
Cameron,
Thank you for taking the time to look into the problems & limitations with Calibration Executive. I appreciate this. Really.
I did have to install Labview on my cal PC. With a very limited number of licenses there were a couple IT guys & engineers unhappy about it, but I have a job to do. The shame of it is that Cal Exec doesn't have this ability built-in. Seriously--a cal program that can't make EEPROM adjustments? Pouring salt in the wound were the errors telling me what to do--but no documentation on HOW to do it.
Of the small pile of red-tagged E-series DAQ cards that had failed in the past I was able to resuscitate one. It had a ludicrous on-chip Cal Temp. stored from the previous cal so any subsequent cal could not match it within limits. The .vi allowed me to over-write the bogus value so calibration could proceed. So at least there was one out here in the field that didn't fail due to a hardware problem.
My bigger issue still remains that this program won't talk to my Standard. I don't have a problem per se with a cal program that only supports one model of calibrator. The problem is we were told via the website AND over a comfirmation phone call that the program would operate in Automatic mode with our standard (as well as other makes/models). Is there some reason NI has written this program to only function with a Fluke 5700 calibrator?
09-21-2012 05:04 PM
Mark,
Where did you originally find the list of supported standards?
09-25-2012 06:51 AM
I'm not sure. I have it as a text file printout so I probably would have done that if it was found only on a webpage (as opposed to a saveable pdf or doc). I recall originally locating it by keyword searching the NI Knowledge Base and Documentation pages but now I can't locate it.
On the page “How Can I Find Available Standards for Calibration Executive in Automated Mode?“:
http://digital.ni.com/public.nsf/allkb/89428763E755573F86256DEA006FE9A1
There is this link referenced :
http://digital.ni.com/public.nsf/allkb/C533B27F38E28F6186256DEA00748CA6
This shows 2 calibrators (Fluke 5500 & Fluke 5700) but the language on the page alludes to much wider support. The program itself only supports the 5700.
My saved list:
Tektronix CG 551AP Calibrator
Tektronix CG 5001 Calibrator
Yokogawa CA100 Calibrator
Fluke 5440B Calibrator
Fluke 5100B Calibrator
FLuke 5720A Calibrator
Fluke 5520A Calibrator
Fluke 5700A Calibrator
Fluke 5500A Calibrator
AOIP SN8310 Calibrator
AOIP PJ 6301 Calibrator
Mensor APC6000 Calibrator
TSI Inc IFA 300 Calibrator
Fluke / DH Ins PPC2+ Calibrator, Controller
Xitron Tech 2000 Calibrator
Datron 4700 Calibrator
Precision Filt 6201C Calibrator
EDC 520A Calibrator
Fluke / DH Ins Molbox Calibrator
Fluke 5101B Calibrator
Fluke 6100a Calibrator, Signal Generator
Fluke / DH Ins PPCK+ Calibrator, Controller
Fluke 9500B Calibrator
Wavetek 9100 Calibrator
Ruska 7615 Controller, Calibrator
Mensor PCS400 Calibrator
Fluke 6105a Calibrator, Signal Generator
Ectron 1140A Calibrator, Other
Omicron CMC 256Plus Calibrator
Fluke 6100b Calibrator, Signal Generator
Fluke 5080A Calibrator
09-26-2012 09:15 AM
Mark,
The Fluke drivers install with Calibration Executive. That is why they would be the only ones to show up. If you want to use different standards, follow the steps listed on this KnowledgeBase article:
http://digital.ni.com/public.nsf/websearch/89428763E755573F86256DEA006FE9A1?OpenDocument
09-26-2012 11:58 AM
That guide was followed by my Labview & IT guys but it didn't work. All it seemed to accomplish was to add the 5100B to the menu list of Sources. The 5700 that is supported has a library folder, .dll's, .vi's, references in .ini files and many others. The 5100 has only 3 tiny code files in the ivi download. The driver downloads for the 5100 vs. the 5700 are totally different in content / file types.
