03-20-2006 10:00 AM
03-22-2006 12:07 AM
Hi confused...
I suggest taking a look at the analog output examples that should have installed with your DAQmx drivers. If you are using Labview, you can browse these examples using the Example Finder (open Labview, click Help -> Find Examples...). Under the Browse window, select Hardware Input and Output -> DAQmx. Examples written with other programming languages can be found in the National Instruments directory, which by default is installed to C:\Program Files\National Instruments\NI-DAQ\Examples (assuming you are using Windows).
Hope this helps!
-Justin
03-22-2006 09:04 AM
