Multifunction DAQ
How do I use Digital Output and Analog Inputs within the same Application
Using a DAQ Card in association w/ a SCB-68 terminal block.  How do I control two different Digital Output, while using (monitoring) a voltage signal on an Analog Input channel?
(2,764 Views)
I'm the Aurthor of the posted question; I should have indicated in LabView
(2,762 Views)
Here is a great <a href="http://digital.ni.com/public.nsf/websearch/851A80A7AB2885E086256F4D000610E6?OpenDocument">Knowledge Base</a> for doing this.  There is even some example code attached.
Also, if you are looking for some other information on synchronization you can view these two resources:
<a href="http://zone.ni.com/devzone/conceptd.nsf/webmain/2638A8DA4E4CFD1F86256D250070C09">Timing and Synchronization Features of DAQmx</a>
<a href="http://zone.ni.com/devzone/conceptd.nsf/webmain/6dc991028566309886256f990080a720">Advanced Data Acquisition Series- Synchronziation with NI LabVIEW and NI-DAQmx</a>
I hope this helps, and please let me know if you have any further questions after looking over all of this material.  Thanks, and have a Great Day!
George M.
(2,743 Views)
