Thanks for the info. You can use the example called Cont Acq&Graph Voltage-Int Clk found in the NI Example Finder. In LabVIEW, go to Help=>Find Examples. Once the NI Example Finder window pops-up, go to Hardware Input and Output=>DAQmx=>Analog Measurements=>Voltage and look for this example.
You will be able to set the number of scans (Samples to read) and the scan rate (Sample rate) to a fixed value. You can take data for user determined times by placing the function Wait or Wait Until Next ms multiple functions inside the while loop.
Hope this helps,
LA
