Matt,
Although NI-DAQ is available on our website for download, the download license states that it is intended to 'update' previously licensed versions of NI-DAQ. An original license comes with NI-DAQ and the purchase of National Instruments hardware. So installing a download version of NI-DAQ on to a computer that does not have an original licensed version of NI-DAQ is in violation of the license agreement.
Ron,
I will look into this issue for you. However, NI-DAQ is designed to be used with NI hardware (hence the clause in the agreement you mentioned about distributing the driver in whole or in part). And even if your .ocx does not directly compete with any NI software packages, utilizing NI-DAQ with another manufacturers board does seem compete with NI hardwa
re. Is it possible to remove any calls to nidaq32.dll from you .ocx and still have it function properly?
Mike Tyler
DAQ Marketing Engineer
