Multifunction DAQ
How do I determine if a global virtual channel allows interactive editing?
Using the DAQmx Save Global Channel.vi I can assign a Boolean True/False for the allow interactive editing? setting, which controls whether or not an operator can interactively change global channel settings using MAX (Measurement & Automation Explorer).
But if I don't already know the allow interactive editing? setting of a particular global channel, how do I read it programmatically?
(2,784 Views)
Accepted by topic author wireman
There is the DAQmx Persisted Channel property node that helps you read that setting.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,778 Views)
Adnan,
Great! Thanks- that's just what I was looking for!
(2,765 Views)
