Hi Abraham_G,
Can you tell us more about the circuitry behind the motor controller? Has this already been implemented? If so, what hardware/software is it using? What kind of signal are you sending to your motor for control?
I believe that an event triggered acquisition may not be the right way to go about this problem. If the main goal of this application is to simply track how many times the motor turned on and retrigger your temperature acquisition, I suggest you set up a simple AI task for your temperature sensors and have it trigger our data acquisition when the motor turns on. You can then have a conditional to stop your acquisition (i.e. when temperature exceeds an upper limit or motor stops?) and increment a software count in your program. Since you say that the motor will turn off for a couple of seconds, this should give you enough time to restart the task and wait for the next trigger to occur.
This is just one possibility of developing this application, but please let me know if I misunderstood your question.
S_Hong
