01-18-2006 10:06 AM
01-18-2006 10:25 AM
When you use DAQmx Create Virtual Channel, you have the maximum and minimum value inputs. These are what set the gain. The driver will set the voltage range to the best available based on your inputs.
I had to look at some of your other posts to verify that you're using LabVIEW and DAQmx. In the future, it's helpful if you can include the software you're using in your post so people don't have to guess.
01-18-2006 11:45 AM
01-18-2006 12:32 PM
