How can I tell how much memory is on my NI 6133 DAQ card?
I have an NI 6133 Daq card but I do not know if it is the 16 or 32 Megasample model.  How can I tell?
Thank you
Kevin Brown
(2,632 Views)
Accepted by kevin.brown
Hi Kevin,
You should be able to find this by reading back the Input.OnbrdBufSize attribute (DAQmx Buffer Property Node in LV, DAQmxGetBufInputOnbrdSize in C API).  To do this, you'll need to create an AI task.
Dan
(2,626 Views)
Thanks, that was the trick.
(2,602 Views)
