I would like to reset a PCI-6731 analog output card.
I'm trying to use DAQmxResetDevice but it doesn't work exactly like I want.
For example, If there is a 3V output voltage on Dev1/ao0. I apply the DAQmxResetDevice(Dev1) function. After that the output is still at 3v.
Is there a function allowing to reset the device and to return its output to 0v under CVI 8.5.
James
Message Edité par julesjay le
11-29-2007 10:13 AM
