‎03-18-2014 06:42 AM
I have two usb daqs from NI, and they are currently labeled Daq1 and daq2, the problem is that each works only with a specific program sicne the daq assitant is only configured to one. I tried to configure it to both but got a does not support multiple devices error. What I want is to take any DAQ plug it into any PC I have running my program and have it work. Both are collecting the same data and both programs are otherwise identical.
‎03-18-2014 07:24 AM
‎03-18-2014 07:30 AM
How can I rename the other daq in max? it has both listed and if i try and turn daq2 into daq1 it says name in use. deleting one to rename the other and vice versa seems to be an endless loop....
‎03-18-2014 07:34 AM
‎03-18-2014 07:36 AM - edited ‎03-18-2014 07:37 AM
I don't. here's the setup:
Laptop #1, has the program executable and only works with DAQ1 daq.
Laptop #2 also has the program executable (and a copy of labview for editing) and only works with daq2 daq.
If go in max on laptop #2 both my daqs are listed ( i assume because that is where the program was written) so i cannot change the name of one so they are identical in the program. meaning that only the daq selected in the daq assitant for that executable/program version will work with that daq. how can I change this so that I can plug daq2 into the daq1 laptop?
‎03-18-2014 07:57 AM
‎03-18-2014 07:59 AM
Removing it does not remove it from MAX it just gets grayed out. I only had both plugged in at the same time for that one instance, otehrwise they are never both in use on one PC. I will give it another try though.
‎03-18-2014 08:31 AM
‎03-18-2014 08:51 AM
‎03-18-2014 03:25 PM
To use the old name, do either of the following before renaming your newly plugged in DAQ device.
1. Right Click on the disconnected DAQ device in MAX and select delete.
2. Rename the disconnected device to something else.
The DAQmx Device Name Control populates itself with the devices currently present in your system--to get a passable dialog box you could just use this within a modal window.
Best Regards,
