Multifunction DAQ
How can I make n-bit data generator?
clock, data, enable
How do you make a 9 bit data generator using these three?
I want to use this code to express 9 bits of data in a square wave on the instrument.
The frequency and amplitude must be adjustable in the code.
Please, let me know.
I use Daqmx program.
(2,418 Views)
You should search for some example codes in LabVIEW.
There are some voltage output example codes.
"Voltage - Continuous Output.vi"  would be helpful to your application.
Here is the instruction to find out examples codes.
http://www.ni.com/getting-started/labview-basics/examples
(2,377 Views)
