Multifunction DAQ
How can I get 6704 output working under Linux?
I want to do Anaolg output with a 6704 card under Linux (preferably with gnu C++). To my understanding, EDaq only works with E series cards, and the Comedi drivers work for Analog In only (in any event, 6704 was not listed in their supported hardware section). Do I have any other options?
(2,405 Views)
Unfortunately, National Instruments does not provide a driver for the 6704 card under the Linux enviroment. You could try and use Register Level Programming (RLP) to program the board in Linux. I have attached a preliminary RLP document for the 6704 and more information can be found on the National Instruments website on how to program various NI DAQ cards via RLP at www.ni.com/support/daqsupp.htm
The following disclaimer comes attached to the RLP for 6704 word document:
Disclaimer: This document is not guaranteed accurate!
It is a preliminary copy of the manual.
Use this document in conjunction with:
"PCI E-Series register level programming manual"
http://www.ni.com/pdf/manuals/341079b.pdf
and possibly
"DAQ-STC programmer manual"
nuals/340934b.pdf
Along with the AO RLP examples on the DAQ RLP page
www.ni.com/support/daq/program/reg_prog.htm
Hope this helps you get started.
(2,405 Views)
