Now I've found the videos at http://www.ni.com/dataacquisition/d/nidaqmx.htm that explain how to use the USB 6008 with VisualBasic, VB .NET and so on. How can I download the videos ? Are they on youtube oder somewhere else ?
unfortunately the Webcast and Videos cannot be downloaded. For what concerns Java, it is not officially supported but feasible since NI provides a Java Interface for National Instruments Drivers. however, my suggestion would be to use either LabVIEW or one of the .NET languages (Visual Basic, C++ or C#) to program. With both LabVIEW and .NET, you will have full access to the DAQmx libraries, example programs, and much better NI support. Here are some links to get you started doing DAQ with Java.
