Multifunction DAQ
How can I do this? - Get Analog Input Gain for DAQ Device
Is there a way to interrogate an E-Series card to determine the current gain setting?
I'm using CVI with DAQmx, an SCXI chassis with modules and a PCI-6071E card. You use a DAQmx command to set the channel max, min, units, etc. and DAQmx sets the appropriate gain setting for the daq card in the computer to maximize resolution. What I really want to do is report to the user what that resolution is.
Without a function call, I have to use the inputs to try and calculate what gain setting DAQmx is going to use, but I'd like to know for sure by asking the card. If I could do that it would be an easy calculation to then be able to display the resolution in the proper units.
What I really need is something like DAQmxGetChannelResolution() that would return the resolution in the units for that particular channel. Either way, I can't seem to find any function calls to let me get to the final combined resolution easily. Can someone help?
(3,361 Views)
Accepted by topic author scottrod
Found it!
DAQmxGetChanAttribute (SCXITaskHandle, DAQStr, DAQmx_AI_Resolution, &resVal, 0);
(3,322 Views)
