08-22-2007 12:17 AM
08-23-2007 10:22 AM
08-23-2007 12:15 PM - edited 08-23-2007 12:15 PM
Message Edited by Bassett Hound on 08-23-2007 12:15 PM
Message Edited by Bassett Hound on 08-23-2007 12:16 PM
08-23-2007 07:12 PM
Hello Ima, Steve,
Thanks very much for your replies.
Ima, thanks for pointing out the R series cards. I had not really had a good look at them before and they would definitely do what I want except for this particular application, because it has to be battery powered and EXTREMELY rugged, it is more likely that I will have to use the compactRIO and 9401 approach. I don't however see that there would be any use in connecting the R series to C series modules through the cRIO 9151 as the IO lines would be then subject to the same transmission delays as the FPGA in the compact RIO. The R Series would be great to interface to customised interface circuity though and I will look at this.
Steve, I had looked at the specs but somehow only after reading your post did it tweak in my head that the delays are probably more serious with output switching. One really important thing you pointed out to me is the dependance on the number of channels being read from or written to which I did not expect or register earlier.
I will have to do a little more testing on multiple channel reads at 20MHz frequency with input signals out of phase on each channel. Going to be hard/expensive to do that on multiple channels. I will try and post back with results when I can.
Thanks again for your help guys!!
Cheers
Peter
08-23-2007 08:29 PM
