Multifunction DAQ
High noise in NI 6353
I am using NI 6353 & NI-SCXI 1000 (1520) For Data acquisition analog input with differential signal. In SCXI-1000 there is no noise but in 6353 very high noise generated. And using 6353 with single ended the noise ratio exceeded. Any one help me for solution.? Plz
(1,459 Views)
A lowpass filter always helps  🙂
What is your signal bandwidth?
Greetings from Germany
Henrik
LV since v3.1
(1,335 Views)
Hello
How did you connected to measurement points?
What kind of parameters your signal have?
__________________________________________
The best way to thank, is to give KUDOS
(1,317 Views)
