Multifunction DAQ
Help on Selection of a suitable PCI/DAQ Hardware setup
I am doing a project which involves 2 different sensors with different Sampling Rates.
My Encoder needs a Sampling Rate of 6.25MHz & my analog sensors needs 100KHz Sample Rate.
Can someone please Guide me how to select a suitable NI Hardware(PCI/DAQ)...!!!
(697 Views)
Assuming that the encoder can be interfaced by a counter and that the number of analogue signals is limited, a multifunction I/O device will be suitable. As the sampling frequency of the analog inputs of the following cards depends on the number of channels, these models are suitable for 100kHz acquisition:
  • ≤ 2: PCIe-6321
  • ≤ 5: PCIe-6341
  • ≤ 10: PCIe-6351
(674 Views)
Thank You for the suggestion.
Will the Encoder Sampling Rate be achieved (6MHz)..?
If i connect it to a 8 channel DAQ/CDAQ, can each channel acquire data in different Sampling Rate...?
(653 Views)
Before choosing a multiplexed input DAQ, have a close look at the specification (settle time error)  and check if your signal sources are low impedance.
I had too many problems with such cards while reading multiple channels, so I always try to avoid multiplexed inputs and choose simultainious sampling DAQ.
Greetings from Germany
Henrik
LV since v3.1
(636 Views)
