Sorry if this is in the wrong section. I have a HSI captive stepper motor that is going to be driven by an IMS483IE driver - http://www.imshome.com/im483i_ie.html. I only need to drive the motor forward and then program a trigger (in Labview) such that when a certain point is reached the motor will reverse. I have a SCC-2345 board and was considering the SSCD001 single channel digital output module to send a signal to the motor driver for either forward or reverse control. I didn't want to have to go down the costly road of using a dedicated motion control board etc., Does anyone see any limitations to this setup or have encountered something similar?
Cheers,
Dave
