Multifunction DAQ
Getting a null task stream handle SOMETIMES using DAQmx 8.6
I'm doing a triggered read on some analog inputs. Periodically, I have to terminate and restart the task because i'm changing the trigger line between "up" and "down" (pfi8 and pfi9).
Here's the code that (re)sets up the read:
if (null != _psdTask)
   _psdTask.Control(
TaskAction.Abort);
   _psdTask.Dispose();
_psdTask = new Task();
//Create a virtual channel
_psdTask.AIChannels.CreateVoltageChannel(GetSampleLines(), string.Empty,
     AITerminalConfiguration.Differential, -10.0, 10.0, AIVoltageUnits.Volts);
//Configure the timing parameters & set it to retrieve exactly N samples
_psdTask.Timing.ConfigureSampleClock(string.Empty, SAMPLE_RATE,
SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, SAMPLES_PER_CHANNEL);
switch (_trigger)
case PSDTriggerSource.Continuous:
   _psdTask.Triggers.StartTrigger.ConfigureNone();
   _psdTask.Triggers.StartTrigger.Delay = 1.0 / SAMPLES_PER_SECOND_POLLING;
   _psdTask.Triggers.StartTrigger.DelayUnits =
StartTriggerDelayUnits.Seconds;
break;
case PSDTriggerSource.DownSensor:
   _psdTask.Triggers.StartTrigger.ConfigureDigitalEdgeTrigger(GetDownTriggerLine(),
      DigitalEdgeStartTriggerEdge.Rising);
break;
case PSDTriggerSource.UpSensor:
   _psdTask.Triggers.StartTrigger.ConfigureDigitalEdgeTrigger(GetUpTriggerLine(),
      DigitalEdgeStartTriggerEdge.Rising); break;
//Verify the Task
_psdTask.Control(TaskAction.Verify);
// make it never time out
_psdTask.Stream.Timeout = -1; // This is the line with the null reference
The last line sometimes throws a NullReferenceException, and the stack trace ends in my code. I'm assuming the Stream property returns NULL.
Any idea what can cause this (or how to work around it)? I was expecting that Verify() would have reported any issues, but it never throws an exception.
Thanks!
John Duddy
(3,518 Views)
Please do some more probing.  Lets setup a breakpoint prior to the _psdTask.Stream.Timeout line and run the code.  When the code stops due to the breakpoint, navigate back to the code and find _psdTask.  Right click and Add Watch.  Please check if _psdTask is null and then expand out to check if Stream or Timeout is null.  Just looking for more insight.
Samantha
(3,506 Views)
Many thanks for the reply.
Because the NullReferenceException happens only when I access the Stream, and because I access members of the task, and because new() cannot fail in C# without throwing an OutOfMemoryException, I think it's safe to assume that the task is not null.
I can set a conditional breakpoint that stops if Stream is null. As I mentioned, it is very intermittent. It may take me some days to get this done, since the equipment is under heavy use at the moment - I'll keep you posted.
(3,493 Views)
