Multifunction DAQ
Get Current with NI 9227
hi ,
i want to know how i could  mesure the current  of a machine using NI 9227 ,(without messing up with the machine ) .
see the picture below  .
(2,861 Views)
What is the machine in question?
What do you mean by 'measure the current of a machine' ?
Are you trying to measure the current being sourced to the machine? The current produced by the machine?
The Operation and Specification sheet for the 9227 is a good place to get started if you have questions on how to connect the module in question to get a current reading.
How to Measure Current & Current Measurements: How-To Guide are also good resources for you.
(2,830 Views)
Read the fanatastic manual of the machine, buy an appropriate current transformer (inrush current migth be 10 times the value) , find someone who known how to correctly (and savely) wire it . Together with the cal-sheet (or at least the datasheet) of the current transformer, configure the data aquisition to read the current.
Hint: you will need to read the supply voltage in sync to the current to measure the energy consumption.
Greetings from Germany
Henrik
LV since v3.1
(2,823 Views)
