Multifunction DAQ
Get 4 AO channels with PCI-6259 and SCXI-1302
Hello guys,
I am using a PCI-6259 which has 4 AO, all connections are made using SCXI-1302 terminal block. At the forum I found the 50-pin pinout. https://www.ni.com/en/support/documentation/supplemental/18/68f-50m-mio-cable-adapter-signal-mapping...
The way I see only channels 20 and 21 are AO, using channel 23 as ground for both. How do I get the other 2 AO channels the PCI-6259 enables?
Thanks for your help,
Daniel
(4,544 Views)
Hello Daniel.
I'm answering your post making some assumptions. So, after read this, let us know how is your hardware layout, then we could give you a better answer.
I'm supposing that you are using the PCI-6259 to communicate with a SCXI chassis (like a SCXI-1000 or SCXI-1001) through a SCXI-1349 connector and then, you might be using a SCXI-1180 with the SCXI-1302 connector block to get access to the PCI-6259 I/O pins.
So, If I'm right, you will not be able to use all the AO channels of the PCI-6259, because the 4 AO channels are divided in each PCI connector, as you could see in the page A-106 of the DAQ M Series User Manual found in the link below.
https://www.ni.com/docs/en-US/bundle/pci-pcie-pxi-pxie-usb-62xx-features/resource/m-series-user-manu...
And why you can't use all the AO channels? Because one of the connectors of the PCI is being used to communicate with the SCXI chassis, so you have available only one connector of the PCI which give you only half PCI's I/O. One possible solution is use only the PCI-6259 with two SCB-68 conectors block, without the SCXI. Or you could keep continue using the SCXI system but add an additional SCXI AO module, like the SCXI-1124.
I expect that I've helped you and feel free to make any further question.
(Note: If it be more confortable, you can answer this forum also in portuguese)
Sincerely.
Marcio Soares
National Instruments Brasil
www.ni.com/suporte
(4,494 Views)
Marcio, você está certo em relação com o hardware utilizado.
Então pelo que entendi a PCI-6259 possui duas saídas no computador, cada saída possibilita apenas 2 AO.
Assim posso continuar utilizando o SCXI com as duas saídas AO do SCXI-1349 e conectar outro terminal, como por exemplo SCB-68, na segunda saída da placa PCI.
Faz pouco tempo que trabalho com o sistema NI e aqui no laboratório o pessoal sempre utilizou as mesmas soluções. Sua resposta foi de grande ajuda!
Grato,
Daniel
(4,487 Views)
Boa tarde, Daniel.
Isso mesmo. Se você olhar de frente para a placa PCI-6259 verá dois conectores, conector 0 e conector 1 (conforme imagem abaixo). Um deles, provavelmente o conector 0 está sendo usado para fazer a comunicação com o sistema SCXI, logo para ter acesso aos 2 canais de saída (AO) desse conector você precisa usar o módulo SCXI-1180 + o conector SCXI-1302. E para usar os outros 2 canais da placa que sobram no conector 1 será necessário possuir um bloco conector SCB-68, ou SCC-68, ou qualquer outro modelo de bloco conector de 68 pinos + um cabo SHC68-68EPM, por exemplo. (As configurações de acessórios para está placa estão disponíveis neste link: https://www.ni.com/en-us/shop/category/multifunction-io.html?productId=118688)
Atenciosamente.
PCI-6259 connectors
Marcio Soares
www.ni.com/suporte
(4,480 Views)
Marcio, muito obrigado pela resposta direta.
Grato,
Daniel
(4,474 Views)
