Multifunction DAQ
Generating 4 analog output waveforms with different frequencies
Hi, I am using Labview. I can select the channel from the browse, but there is no option like" Dev2/ao0:1. I wonder how to make two channel output simultaneously
Message 61 of 65
(758 Views)
That makes no sense. You have the browse option so simply shift click or ctrl click to select multiple channels.
Message 62 of 65
(755 Views)
Well I am using USB 6351, the device name is Dev2. When I click the physical channel, there are two options showing up: dev2/ao0 and dev2/ao1. So do you mean by Ctrl+ click ?
So I did not catch your point .
Message 63 of 65
(751 Views)
When you click on the control, you get a list with browse at the top and then individual channels. Click on browse and you get a list that you can select multiple channels with ctrl click or shift click.
Message 64 of 65
(744 Views)
Oh thank you! I will try that by tomorrow.
Message 65 of 65
(741 Views)
