Forumi,
You can generate the 5 square waves from 0 to 10V with the PCI-6704, without any problem. However,if you want to generate those same 5 square waves with the PCI-6602, you will be able to do that, but you will need external circuitry, because the pci-6602 outputs only TTL compatible signals; thus, there must be amplification of those signals in order to reach the desired 10 V. However, the update rate can be reached easily. Furthermore, if you want to synchronize both boards, that's not possible, because the pci-6704 does not have a RTSI bus, which allows it to get synchronized with the rest of the boards.
Finally, the latter board is an E Series one, and you can only output up to 2 analog signals out of it. You can accomplish the desired specifi
cations,but not the number of output signals.
Regarding connections, you can check the User Manual for each board. I add the links below:
*http://digital.ni.com/manuals.nsf/websearch/08CD9D9AB565FC888625676700526D8D?OpenDocument&node=132100_US
*http://digital.ni.com/manuals.nsf/websearch/DD0DBB6404BC139886256721007CF16D?OpenDocument&node=132100_US
*http://digital.ni.com/manuals.nsf/websearch/D5083F9A8DB75A6D8625665E0063587B?OpenDocument&node=132100_US
If you have further questions, please be more specific next time. Thanks!
Hope this helps,
L Aguila
Appplications Engineer
