10-18-2012 04:01 AM
in the user manual of USB-621x family card you can find the different analog input ranges but the corresponding NI-PGIA gains are not mentioned.
As an example, if you choose the "–200 mV to 200 mV" analog input range, does it mean that a gain of 50 is applied by NI-PGIA to the acquired
input signal?
In other card series, as an exmaple the E Series, the gains applied by NI-PGIA corresponding to the different input ranges are reported in the user manual.
10-22-2012 01:11 AM
yes, you are right!! In the example you posted, the gain 50 is apllied to the input measured signal when you set the input range to -200 mV ; 200 mV.
Best regards.
Cla_CUP
