Multifunction DAQ
GPS NI-9467
I am looking into ways to have a time and position saved to the cvs file that is created in our VI that take many test point in aircraft flight test.
Right now I have to download the GPS data from the Garmin (or other gps avionics) and sync that data later with our cDAQ test data.
I cannot find documentation that says these modules send a time/position  data stream to the cDAQ other than this is a "The NI‑9467 provides accurate time synchronization for CompactRIO systems."
Can I used this module on my cDAQ and record to file the time/position data?
(1,950 Views)
Duplicate post - https://forums.ni.com/t5/LabVIEW/NI-9467-GPS-Module-Capabilities/td-p/4326393
Santhosh
Soliton Technologies
(1,948 Views)
Yes, But the titles is different and sent to two different boards as I was not sure which board would be the most correct.
(1,937 Views)
Accepted by topic author Ezzell
I have found this https://www.ni.com/en/support/documentation/supplemental/08/c-series-module-and-compactdaq-compactri...
It its say it is not compatible with the cDAQ
(1,920 Views)
