Multifunction DAQ
Floating analog output with USB-6001
I want to control DC regulated power supply with USB-6001.
But, when USB-6001 and other machines are connected to PC's USB ports, loop circuit is created and can not control power supply.
How can I use USB-6001 analogue output in floating mode?
(436 Views)
Unfortunately, USB-6001 does not provide floating output. An alternate option, if 6001 is connected to a laptop that is not connected to the ground by any means (charger, monitor etc.,) the 6001 gnd would be floating since it now becomes battery-powered (through the laptop).
Santhosh
Soliton Technologies
(399 Views)
Hi, Santhosh
Thank you for your comment on USB-6001.
I will change my system without USB-6001.
(343 Views)
