07-06-2008 10:06 PM - edited 07-06-2008 10:14 PM
07-09-2008 08:38 PM
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
07-10-2008 10:53 AM
07-13-2008 08:52 PM
07-14-2008 10:45 AM
07-14-2008 07:56 PM - edited 07-14-2008 08:02 PM
07-14-2008 08:11 PM
07-15-2008 12:01 AM
07-15-2008 12:15 AM
02-10-2009 05:44 PM
Hi, I have a similar issue. I'm trying to do quality stereo I/O measurements, using either an M series NI USB-6211 device, or a sound card.
I'm playing out two tones (4 kHz and 4.8 kHz) continuously and simultaneously measuring the signal with a microphone (particularly distortion components).
I can make the recordings using my USB-6211 DAC/ADC but the inherent glitches on the DAC output are just too high generating distortion components, and I would like to avoid implementing deglitching harware.
I can also record using my crappy laptop sound card, but it's SNR isn't very good.
Currently, with 16-bit I/O on either device, I'm restricted to a SNR of <80 dB, and the equipment noise+distortion is just above the signals that I'm trying to record.
So, I've been thinking about buying a quality 24-bit external sound card, like an E-Mu 0404 or similar M-Audio device, which would only cost around $250.
I realize that there are other more expensive NI DAC/ADC devices that could accomodate the quality I need for my recordings (such as the USB-6281, which has deglitching, or a PCI-4661), but I'd like a device that is both USB and doesn't cost an arm and a leg.
Amplitude stablity or drift isn't too much of an issue (I don't think), and as far as I can tell a quality external sound card would do the trick, but I'm not sure just yet.
Has anyone got any advice on whether I should use a sound card or stick with NI DAC/ADCs? Or how to remove the glitching on my USB-6211 output?
I'm quite willing to hear that I'm a moron and that I've overlooked something too (such as the noise floor or SNR being limited by 16-bit recording).
