Multifunction DAQ
Example of Dataacquisition with a HI-Speed USB Carrier NI USB-9162 and a NI 9239
Hello!
I´m trying to develop an application with  the HI-Speed USB Carrier NI USB-9162 and a NI 9239 Module, but I had problems with the DAQ Assistant about the configuration of the parameters:
Timing Settings:
 Acquisition Modes, Samples to read, Rate (Hz)
I need to get 10000 Samples pro second (10KHz).
An example of my Programm is attached. I hope that someone could help me.
Thanks.
(4,883 Views)
Hi pedrito55,
could you please provide more details about the problem you're experiencing?
The application you've attached is running fine on my system, is there any error messge etc.?
Please also have a look at the example library shipped with LabVIEW, there are plenty of examples there that show you how to perform certain tasks.
Bernd
(4,861 Views)
Thank you for your answer.
The idea is to measure the acceleration of an impact in a specific material sample. The implemented devices are:
- Module NI USB 9239 with HI-Speed USB Carrier NI USB-9162
- Power Supply/Coupler 5118B2
- Miniature-acceleration sensor Typ 8730A500
I have seen in my program that the way to save the data could not be right.
I will try with the example library.
pedrito55
(4,819 Views)
