06-28-2007 09:26 AM
Cal Exec 3.2.1 is giving me problems when trying to cal cRIO-9211 units. This is the error message:
Error -200081 occurred at DAQmx Start Task.vi at step Verify Analog Input
Possible reason(s):
Sample rate exceeds the maximum sample rate for the number of channels specified.
Reduce the sample rate or the number of channels. Increasing the convert rate or reducing the sample delay might also alleviate the problem, if you set either of them.
Number of Channels: 2
Sample Rate: 7.140001
Maximum Sample Rate: 6.000000
Need to know what can be done to fix this, or need a patch ASAP. Customers waiting on modules.
06-29-2007 02:14 PM
