Multifunction DAQ
Error using NIDAQ-examples with lcc
I tried to compile some of the demos using the lcc32-environment. After some time it worked fine using
lcc -c test.c -o test.o
lcclnk test.o test
But when I try to run test.exe I get the following error:
Exception 0xc0000005
Segment violation
Adress: 0x0
abnormal program termination
Any ideas on that? The program I tried to start was Acq-IntClk.c
Thanks!
(3,338 Views)
Hi Mart
thanks for posting to our forums. I have to admit I am not too familiar with the Lcc win 32 compiler. You should take a look at this forum post. The DAQmx C Reference Help mentions at the index "ANSI C" several steps to follow in order to use other compilers.
Good luck with your project!
Peter
Peter A.
Field Sales Engineer, NI Germany
(3,294 Views)
