Multifunction DAQ
Error code -1073807346 from DAQmx Base on running EXE-File
Hello l&g,
My vi under LabView with NI USB-6009 is running good. But if I run the created EXE-File then i receive an error code -1073807346. The source of error is coming from the deepest NI vi's. On this vi's i changed nothing! Can somebody tell me the solution?
Uwe Augst
Muehlbauer AG
Germany
(2,535 Views)
Hi Uwe-
I suspect that the error you are seeing is caused by the problem discussed in this post: run-time application with USB-6009,Error 1073807346 VISA
Good luck with the rest of your application.
Tom W
(2,527 Views)
Hello Tom,
you are right.
Thank you for the fast reaction.
Uwe Augst
Muehlbauer AG
(2,515 Views)
