12-09-2021 05:54 AM - edited 12-09-2021 05:55 AM
Hi All,
I am trying to generate synchronized two analog outputs and one digital output. I was using one code written by someone else. The code was working fine, but now I changed the DAQ card (PCI 6259) to another PC and it's showing the following error:
“Error-50103 occurred at DAQmx Start Task.vi:4
Possible reason(s):
NI Platform Services: The specified resource is reserved. The operation could not be completed as specified.
Task Name: _unnamedTask
I have attached the code snippet and screenshot of the error.
I have checked the analog, digital, and counter output using NI MAX. All are working.
I think the problem is probably from the counter used to synchronize the analog and digital outputs, but I can not fix it.
Could anyone help me?
Thank you!
12-16-2021 02:09 AM
Please find the solution to the error -50103 following this link:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8kmSAC&l=en-US
If you have any further questions, do not hesitate to ask.
