Multifunction DAQ
Error '-2146893801' installing DAQmx
Error '-2146893801' occurred when trying to create a unique temp directory path using the pattern
\\?\C:\Users\rathod2\AppData\Local\Temp\nipkg_preinstall-%%%%-%%%%-%%%%-%%%%-%%%%.
Error while installing NI DAQmx and NI package manager
(242 Views)
What is the question?
(228 Views)
How to solve installation error?
(213 Views)
Maybe provide more detail first?
  1. How are you trying to install this?
  2. Is this on a PC? What OS?
  3. Does the error occur during installation of the package manager or later during DAQmx installation (you said "and")
  4. How full is your HD?
  5. Do you have admin privileges?
  6. ...
(202 Views)
I am getting this error with all installers listed below with admin rights
NIPackageManager25.8.0_online, ni-daqmx_25.8.0_offline, ni-daqmx_25.8_online
I am using a Windows 11 PC with more than 30GB HD capacity available.
I had earlier installed NI Max using NI system configuration. But it did not have drivers to detect USB-6008.
So I tried installing NI DAQmx. This still did not resolve driver issue and I wanted to remove everything and install again. I used NI package manager to uninstall all and also deleted folders from C: drive manually after uninstallation. Cleaned registry of old installation using regedit as I was facing this problem. Looked and tried a lot of solutions suggested online, but nothing works.
(188 Views)
