I tried to calibrate a PCI 6259 M card with the following code:
(Visual Studio 2005, C#, using DAQmx.dll)
public static void ExecuteExternalCalibration(string devicename, double voltage)
Device dev = DaqSystem.Local.LoadDevice(devicename);
try
ExternalCalibrationSession session = dev.StartExternalCalibration("NI");
session.AdjustMSeries(voltage);
session.SaveChangesAndDispose();
catch (DaqException exception)
throw new ApplicationException("NI-Error", exception);
// catch
After calling the method with parameters dev1 and 7 (V) the error 200546 occurs:
"External calibration failed and the external calibration data has not been saved. Make sure, that the reference signal used for the calibration is stable and that the voltage matches the value specified to the calibraton software. Discconnect the device from any external signals that migth be introducing noise."
Is there any problem with my code or with the hardware (I´m using the connector module 2111)? How do I get +7 Volt to ai0 and -7 Volt to ai8?
Thanks for every help, Juergen.
