Multifunction DAQ
Error -200088 with USB 6009
Hi all,
I'm a new user to Labview and trying my first steps. (currently the Demo Version 2013)
I want to read analog values via a USB6009 device. All drivers installed via the supplied DVD
When I try to run my circuit, I'm getting a error -200088.
Can anybody help me with this?
http://monosnap.com/image/El3PZN681rmktFreefMQ2XU14dMuQ6
John
(6,003 Views)
Please don't link to some odd third-party site. You can simply attach images or VIs directly to the board.
I would suggest that you don't mix the DAQ Assistant and the low level DAQmx functions. The error pop-up is also hiding part of your code and it is also unclear whether the error comes from the write or read. I would also suggest you wire the error in/out terminals and not rely so much on the automatic error handling.
(6,000 Views)
Hi Dennis,
Thanks for your reply.
Sorry for linking to some 'odd-site'.
The VI is attached. It was taken from a labview tech-learning site:
http://home.hit.no/~finnh/videos/topics/labview_analog_io/labview_analog_io/labview_io_intro.html
Terminals are wired according the video: Output goes in a loop back to the input terminal.
Maybe you can tell me what is wrong?
BR
John
(5,993 Views)
Like I said, replace the DAQ Assistant. I, like most experienced users, do not use it and I have no idea if there is actually an active task being passed out.
(5,989 Views)
Thanks Dennis for your help.
I'll try it - not sure how to do it now. I need to check some literature first.
Do you happen to know whether there are some good tutorials for the USB 6009 unit from NI ? I can't find any for this specific topic.
Thanks a lot
John
(5,977 Views)
Here is a quick link that I used to get started.
Now Using LabVIEW 2019SP1 and TestStand 2019
(5,970 Views)
Awesome - Thanks GovBob!
(5,957 Views)
