06-05-2008 05:56 PM
06-06-2008 09:44 AM
06-06-2008 03:51 PM
Hi edwarwl,
Can you try running an example that uses an internal clock to see if you receive an error? If it is possible, you can use an internal clock with a rate of 100Hz. You could also generate a 100Hz clock with one of the counters on the board if they are available. You will be able to make this same measurement with an internal clock and then make some adjustments for an external clock.
06-06-2008 04:11 PM
06-09-2008 02:49 PM
Hi edwarwl,
You seem to be experiencing crosstalk between your signals in the cable. I have included a link to a document that explains how to handle several types of noise. You could try changing the lines that you are using in order to decrease the crosstalk. Which lines/pins are you currently using? The SHC68-68-EPM and the SH68-68-D1 have different pinouts and the conductors are not identical. This may be why one cable works with your application and the other does not. Filtering your signal may be an option if you can implement it into your application and have a quality clock signal.
Troubleshooting Unexpected Voltages, Floating, or Crosstalk on Analog Input Channels
http://digital.ni.com/public.nsf/websearch/B9BCDFD960C06B9186256A37007490CD?OpenDocument
