Error-1074001424
While running Cal Exec on an NI-9205 A/D convertor, (Dsub) I get this error message when the Cal/Exec starts the adjust portion of the test.   Error-1074001424 occurred at cex_FL5XMCal_ConfigCalibrator outputAndWait.vi at step adjust. Any help?
(4,242 Views)
Accepted by xr1200
Hello xr1200,
If you’re using a Fluke 5700 Series 1, you could try the next alternatives:
-          Use a Fluke 5700 Series 2.
-          Keep clicking over Retry in the error window, eventually the calibration will complete.
-          If you’re using a PCI-GPIB, try using a USB-GPIB.
If you’re not using it, please describe me your setup. Have a good day!
(4,234 Views)
Thanks so much for the help.
I will try all your suggestions
Thanks   XR1200
(4,232 Views)
