From 08:00 PM CDT Friday, August 12 - 01:00 PM CDT Saturday, August 13, ni.com will be undergoing system upgrades that may result in temporary service interruption.
05-30-2011 07:06 PM
I just started to learn DAQ, and found this error msg constantly showing up when I was trying the example codes.
"Error -10403 occurred at AO Group Config. Possible reasons: NI-DAQ LV: The specified device does not support the requested action (the driver recognizes the device, but the action is inappropriate for the device)." Since this error msg pops up every time, I haven't been able to run any vi yet.
I went to MAX, and tried to configure the channels, but there is only device number option, no channel config option.
Can anybody point out a solution? Thanks.
Exia
Environment:
Windows XP sp3/Win2000 sp4
Labview 5.1.1
NI-DAQ 6.9.3
MAX 2.2.0.3010
PCI-6503
05-31-2011 03:36 PM
Configuring AI (analog input) or AO (analog output) won't work for a device that supports only digital I/O, such as your PCI-6503. The 'Digital I/O Function Group' section in Chapter 3 of the Traditional NI-DAQ User Manual might be useful.
Is using a version of LabVIEW later than 5.1 an option? I would recommend using NI-DAQmx for new development unless you need to use Traditional NI-DAQ (for instance if you have a preexisting application written against the Traditional NI-DAQ APIs), but unfortunately according to the compatibility chart you would need at least LabVIEW 7.0 to do so.
06-01-2011 02:44 AM
We got some old programs running based on even older versions, so the upgrade seems not likely though.
My project was previously running on a Lab-PC 1200AI card, that old PC died and it is not easy to find a ISA equiped computer nowadays. Are there any economical alternatives to Lab-PC 1200AI with either PCI or PCI express interface? and also compatible with labview 5.1.1
Thanks for your time, really appreciate it.
06-01-2011 08:34 AM
Functionally speaking, the PCI-6025E E Series DAQ is probably the closest match:
* Lab-PC 1200/AI: 8SE/4Diff, 12-bit, 100kS/s AI; no AO; 24 DIO lines; 3 8MHz counters.
* PCI-6025E: 16SE/8Diff, 12-bit, 200kS/s AI; 2 12-bit AO; 32 DIO lines; 2 20MHz counters.
The PCI-6025E is supported in both Traditional NI-DAQ and DAQmx. The Lab-PC 1200/AI and 6025E use different connectors (50-pin male ribbon connector vs a 100-pin female D-type), so your cabling will have to change. The 6025E also has one less counter than the Lab-PC 1200/AI, so if you're depending on that then it may not be a fit.
Looking forward, anything newer than E Series (such as M Series or X Series) is going to be supported only in NI-DAQmx, so I do recommend you at least consider upgrading your existing software to use NI-DAQmx in the future. NI-DAQmx provides easier APIs, ease-of-use features such as the DAQ Assistant, and better multithreaded performance than Traditional NI-DAQ; a FAQ is available that further compares the two.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
