I'm attempting to run a simple vi that uses AI Aquire Waveforms.vi to input voltage data that I have coming in from the USB-6008 DAQ. However, when I try running the program, I receive the error:
Error -10401 occurred at AI Group Config
Possible reason(s):
NI-DAQ LV: The specified device is not a National Instruments product, the driver does not support the device (for example, the driver was released before the device was supported), or the device has not been configured using the Measurement & Automation Explorer.
And I'm not sure how to fix it. In MAX, the device seems to be working properly and everyhting seems to work fine in the test panel, so I'm slightly at a loss. I'm running Labview 7.1, and installed NI-DAQmx 7.5 which came with the USB-6008.
