I am trying to self calibrate an AT-MIO64E3 using 'Calibrate_E_Series' under CVI5.0. After the calibration using 'SCAN_op' I regularly (not always however) receive the error message -10007: "Channel out-of-range for device type or input configuration; either the combination of channels is not allowed, or you must reverse the scan order so that channel 0 is last"
Any hints would be appreciated.
Thanks, Matthias
Sent via Deja.com http://www.deja.com/ Before you buy.
