Multifunction DAQ
ENET-9163 C module not supported
Hi All, I have a ENET-9163 case. I find it in the "Netrwork Devices" typing the IP address manually. When I try to add to the list a message appears like "The module is not supported by ENET-9163"
I have tested with NI9401, NI9221 and NI9402 C modules.
When I switch ON the case, only the power LED is ON in green, the others are in OFF
I,m using Labview 2015SP1 with DAQmx installed.
Attached one screen of the problem
Thanks in advance
(3,173 Views)
Accepted by topic author Icaro600
Hi again. Sorry, this happens when you don´t have a look first in the forum
I found a list of the supported modules by ENET-9163, all of the three I tested are not supported.
So case closed.
(3,170 Views)
