Multifunction DAQ
Driver for NI USB-6259 for MAC OS
I want to use the DAQ: NI USB-6259 for my MAC (labview on MAC). How do I write a driver for it? Are there any other DAQs with 32 channels at >30kHz sampling per channel, that I can use for a MAC.
(2,952 Views)
asdfghas,
To first answer your question, the USB-M Series devices are not supported on a Mac.  We do have a Measurement Hardware DDK for use with Mac OSX, but it will not work with USB devices yet.
There are devices available to take 32 channels of analog input at >30kHZ sampling for a MAC.  But they will all be of the PCI form factor, and will use the DAQmx Base driver.  There is an exact equivelent of the USB device you mentioned in a PCI form factor, the PCI-6259.
You can find more information about National Instruments Harware products that are supported under the Mac at http://www.ni.com/mac/daq.htm.
Josh W. | National Instruments | Applictions Engineer
Josh W.
Certified TestStand Architect
Formerly blue
(2,940 Views)
