Multifunction DAQ
Driver NI DAQPad-6015 in Windows 10
How to install the driver to NI DAQPad-6015 on Windows 10?
I downloaded e trying do install from
http://sine.ni.com/psp/app/doc/p/id/psp-229/lang/pt
but don't recognize in Device Manage.
Any idea?
(5,219 Views)
Accepted by topic author eleilson_s
The DAQPad-6015 is not supported on 64-bit Windows 10. They are only supported on 32-bit Windows. From the NI-DAQmx 17.6 readme.html:
Legacy DAQ Devices
The following legacy DAQ devices (also called B Series devices) are supported:
Device DAQ Pad PCI USB
NI DAQPad-6015*
NI DAQPad-6016*
NI PCI-6010
NI PCI-6013
NI PCI-6014
SensorDAQ
* Not supported on 64-bit versions of Windows 10/8.1/7
Brandon Streiff
ni.com/compactdaq · ni.com/daq
(5,218 Views)
Hi Eleilson,
Unfortunately, the drivers for NI DAQPad-6015 are not supported by 64-bit operating systems because the DAQPad-6015 were discontinued in 2015.
You can use any other 32-bit operating system, such as Windows 7-32Bits, XP or 2000.
Or depending your application, it may be interesting to update the hardware used.
Isabelle Orlandi
Engenharia de Aplicações
National Instruments Brasil
(5,177 Views)
Thankyou Brandon Streiff.
Obrigado Isabelle
(5,165 Views)
(5,164 Views)
Why is there no support for this hardware? Is there a third party solution?
(2,570 Views)
Unfortunately, this product is so old that it is beyond its product lifecycle and hence NI would have discontinued support. No, there is no third-party support as this is NI Proprietary hardware.
Santhosh
Soliton Technologies
(2,566 Views)
