I'm going to modify an acquisition system based on the PXI-6052E board.
When having a look at the 6052 data sheet before to start working, I discovered that the hardware block diagram doesn't show any anti-aliasing filter before the MUX. (The same diagram for the S-Series multifunction boards does show it, but in that case there is also a specific ADC converter for each channel, therefore no MUX)
Does it really mean that there is absolutely no filter in the 6052 or it is just not specifically reported (maybe included in the MUX block)?
Thanks in advance!
