Multifunction DAQ
Does Anyone know how to save a named channel (.Daq file) as the default in Measurement explorer 2.1?
Everytime I reboot it defaults back to the basic installed .daq. If I can not save a default file, is there a way to dynamically assign the file in VB or C++?
(2,088 Views)
You can save your configuration file and set it as the active file by using the Tools>>NI-DAQ Configuration menu in MAX.
Hope this helps.
Erin
(2,088 Views)
