Multifunction DAQ
Do you have some examples on how labVIEW can take a value of 1 to output a high (voltage) to a DAQ system to turn on an LED?
I am using LAbVIEW 6.1 and need some help making the SCXI 1325 turn on a LED
(2,273 Views)
The SCXI-1325 is a terminal block. It should be connected to an SCXI module (probably an SCXI-1124). You may have to remove the terminal block or look in your configuration to determine your module. Once you know the module, look in examples\daq\scxi\... for examples. You can also go to the menus under help>>Find Examples... and browse or search for examples.
Doug
(2,273 Views)
The 1325 is a terminal block only. To be more precise on the example that will work on your application, you would need to post which SCXI module you are using there.
Anyway, you can take a look at the Labview shipping examples that handle digital lines at Find Examples-> Hardware Input and Output->DAQ-> Digital Input and Output->E-series.
Hope this helps.
Filipe
(2,273 Views)
