Disconnected cDAQ-9188 in Measurement & Automation Explorer
I try to connect to a cDAQ-9188 device with Measurement & Automation Explorer.
I can find the device because I have its IP address, I can see it in the left treeview, but its icon is set to "disconnected" (see picture)
When I want to reserve the chassis I've got an -88705 error saying that the device is not activated.
I'm using Windows Vista SP2, and I just installed NI-DAQmx 9.3. Measurement & AUtomation Explorer is version 4.8.0f0
Thank you in advance for your support
Greetings
J-D Gasser
Message 1 of 11
(7,629 Views)
Hm. Interesting. Network cDAQ devices that have been added to the system should not have that icon.
You said you just installed DAQmx 9.3; were you upgrading from an earlier version? (Note that you'll need to upgrade the firmware on the cDAQ-9188 to 1.1.0 in order to use it with DAQmx 9.3, but that's not the cause of this issue.)
Is there a yellow-exclaimation overlay on the cDAQ-9188 in the Windows Device Manager? If so, what does the 'Device status' field say?
Have you tried removing the device from MAX (right click and select 'Delete') and re-adding it?
Message 2 of 11
(7,625 Views)
Hello  bstreiff,
thank you for your answer.
I upgraded DAQmx from an older version, but I can't remember which one. I already upgraded the firmware and you're right it didn't solved my problem.
I didn't had any warn in Windows device manager.
I'm currently uninstalling everything concerning National Instruments from my PC and will do a new "almost clean" install.
I will keep you inform once I finished the new install.
Greetings
J-D Gasser
Message 3 of 11
(7,623 Views)
I tried to uninstall / reinstall everything concerning National Instruments, but it didn't solved my problem.
I always have the "disconnected" icon in the network devices list.
What is strange is that when I try to reserve the device I have these two messages : (see pictures)
1. "Another system has already reserved the chassis. ... " (translated from french) .. and when I click OK, I receive this second message :
2. "Unable to reserve the chassis. Error -88705 ... " (translated from french)
Does anybody knows how to solve my problem ?
Message 4 of 11
(7,611 Views)
Same issue here...
Its strange that MAX detects the modules... it even updates when I move the modules around...but does not allow me to Reserve the Chassis
And I do have the right firmware... 1.1.0f0
Message 5 of 11
(7,585 Views)
The 'another system has reserved the device' error is normal; if you uninstall and reinstall DAQmx, then the device thinks your host is a different instance of DAQmx.
Have you tried doing a factory reset on the device? While the device is running (power applied), hold down the reset button for five seconds. The device will then reboot with original settings.
Message 6 of 11
(7,576 Views)
bstreiff,
Yes... I have tried the reset (hold reset button for >5 sec)... back to the same issue
-Som
Message 7 of 11
(7,572 Views)
J-D Gasser,
Do you have any other NI hardware that you can try on the machine?
Does your system detect any other NI DAQmx device? USB cDAQ?
I seem to have the same issue as you on the ethernet cDAQ... but now, I cannot detect my USB-cDAQ device on the machine...
-Som
Message 8 of 11
(7,564 Views)
All,
After noticing that even my USB cDAQ chassis was not detected by MAX.
I uninstalled the DAQmx 9.3 driver and re-installed it. This seemed to fix the issue.
I can now detect my USB and ethernet cDAQ chassis.
-Som
Message 9 of 11
(7,558 Views)
thank you for your answers.
I already tried to deinstall and reinstall everything on my PC with Windows Vista.
I reinstalled all the lastest drivcers and softwares, so I think it's not a problem of version.
What I did yet is to install it on a virtual XP machine and everything works on that machine.
I have to go ahead with the developpement of the software that will use NI hardware, so until I did not found any other solution I will debug on that virtual machine with remote debugging.
But feel free to purpose any other solutions to make Measurement & Automation work on my machine.
Message 10 of 11
(7,547 Views)
